Всем привет! у меня такой вопрос! может кто нибудь ставил ! подойдёт ли блок абсс saab 9-5 2004 c esp на saab 9-5 1998 без Esp количеством трубок совпадают
http://www.saabcentral.com/forums/showthread.php?t=371938 - тут с фотками установка ESP в машину без ESP цитата: The following parts are required: ESP hydraulic unit, part no 5392790 New brake pipe between ESP unit and brake cylinder, designed for ESP, 5231071 Steering wheel column, 5208343, with a steering angle sensor, 5235783 (note that for 2002, the column has a different part no) Yaw rate sensor, 5060710 Console for the yaw rate sensor, 5390265, 2 nuts 11900451, 2 screws 11900354 Switch for the dash board, 5241245 7 cable shoes to the ESP unit connector, 4466801 Connector to the yaw rate sensor, 5241278 6 cable shoes to the yaw rate sensor, plus another 3 to the brake pressure sensor, 5351747 Connector to the steering angle sensor, 5241286 4 cable shoes to the steering angle sensor, 5249297 Cables in different colors 2,5 mm^2 (and the right specification concerning temperature range) This guide assumes a car already equipped with TCS (traction control system). It should probably work on a car equipped with ABS only– but then a P-bus connection needs to be wired to the ESP unit in the engine compartment Work list: 1. Install a new wiring harness through the firewall to the ESP hydraulic unit 2. Install a yaw rate sensor on the center console under the gear stick housing 3. Replace the steering wheel column with one with a steering angle sensor 4. Install new wiring harness to the steering angle sensor and connect it to the P-bus 5. Replace the hydraulic unit with one with ESP-function and connect the wiring from the integrated brake pressure sensor and the yaw rate sensor to it. Replace the brake pipe between the hydraulic unit and the brake cylinder and finally bleed the brakes 6. Perform a calibration of the steering angle sensor with a Tech-2 7. Replace the TCS switch on the dashboard with a ESP switch
Никто не в курсе, обязательно брать блок esp с таким же номером как стоял? А то товарищ уже на второй машине меняет, берет со словами"мне просто с esp", потом ставит, ему его прошивают и все работает.
