Мысли вслух. Кратко.
Тема в разделе "Курилка", создана пользователем Vladimir ® *WehrWolf*, 17 окт 2008.
  1. Vladimir ® *WehrWolf*
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CBuba%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Просто порой раздражает общество со своими дибильными правилами...<o:p></o:p>
    Они сами не знают зачем они нужны. Это как недавно один человек рассказывал про опыт:
    <o:p> </o:p>
    Садили обезьян в клетку. Посередине лестница. Если взобраться - можно сорвать банан.<o:p></o:p>
    Но последняя ступенька на лестнице электрифицирована(т.е. бьет небольшим зарядом тока)<o:p></o:p>
    Так вот. Запустили обезьян, те увидели банан, поперлись.. БАЦ.. каждую ударило.<o:p></o:p>
    Прифигели обезьяны и решили не суваться. Потом ученые выключили эту байду с электричеством.<o:p></o:p>
    Вытащили одну обезьяну из клетки и затащили новую.. Естественно увидев банан, та хотела полезть по лестнице наверх.<o:p></o:p>
    НО.. остальные обезьяны то уже знаают, что мол нельзяяя... а то больно будет.<o:p></o:p>
    И мало того, что не пустили, так еще и напинали её за это) Потом так поступили с еще одной обезьяной..<o:p></o:p>
    вытащили и втащили новую.. её снова напинали другие. И так сделали с каждой пока не перебрали всех тех, кто своими глазами видел, что там бьет током.<o:p></o:p>
    НО.. при запуске новых обезьян, даже те кто не видели электричества продолжали не пускать новых обезьян к банану.<o:p></o:p>
    <o:p> </o:p>
    Что показывает этот опыт ? Силу идеологии.. традиций.. люди не понимают, что они делают, они ток догадываются, мол так принято (возмущен до глубины души)<o:p></o:p>
    <o:p> </o:p>
    А взаимное уважение, это без проблем =)<o:p></o:p>
    Ну не зря же мы из обезьян выросли...)) Но обществу ведь нужны правила...<o:p></o:p>
    надо на что-то ориентироваться, а ориентируемся мы обычно друг на друга.<o:p></o:p>
    Просто нужны общепринятые нормы во избежание вселенского хаоса.<o:p></o:p>
    Другое дело, что нормы эти порой совершенно идиотские))...<o:p></o:p>
    <o:p> </o:p>
    И без них люди не могут, т.к. считают, что в том, что они уже делали и умеют есть нечто, что спасёт их вид, в принципе логика в этом есть, но порой слишком извращенная, <o:p></o:p>если смотреть, то можно увидеть, что многие эстеты прошлого были жестокими изуверами, а наоборот люди простые могли сопереживать и т.д.
    <o:p></o:p>
    Следовательно вопрос: культурный ли человек знающий классику, этикет и нормы поведения в обществе, но при этом законченный циник и не видящий ничео плохого в том,<o:p></o:p>
    чтобы уничтожать всех "кто, не соответствует" (есть такое психическое заболевание)? И таких вариаций может быть много.<o:p></o:p>
    <o:p> </o:p>
    Культурность человека не может определяться по какому-то шаблону, в каждом случае свой подход, все неповторимы)<o:p>
    </o:p>
    таково моё мнение (запутанно правда). Засыпаааюююю.
  2. ko4evnik.
    ko4evnik. Новичок
    Москва-Бежецк
    9000 2,3t АКПП 1995
    Что с тобой случилось-то?
  3. Afrika
    Afrika Пользователь
    Веста
    9-5 М98 2.0 АКПП был. х-трейл сейчас тоже ушёл. Тазовод.
    Осеннее обострение в связи с нехваткой солнца....
    М-да-а.... А ведь всё только начинается....
  4. Хомяк
    Хомяк Администратор Команда форума
    Культурность, так же как и этичность, аморальность и правильность поведения определяется самим обществом в данный момент времени.
    По принципу "что русскому хорошо, то немцу - смерть!"
    Что хорошо и нормально для дебилов, зеков или, например, просто панков (ругаться матом, испражняться на улице у всех навиду, избивать слабого), то может считаться неприличным и аморальным в "цивилизованном обществе" (как они сами себя часто называют).
    Для первой категории это не только нормально, но и жизненно "необходимо" для удержания собственного статуса в окружающем их обществе. По той же причине те же действия и поступки неприемлимы для второй категории.
    Вопрос: к какому обществу причисляет себя каждый индивидуум в отдельности и в каком обществе он хочет жить.
    Шаблон общества определяется установленными внутри него правилами. Без правил общества не бывает. Даже на зоне или в диком племени каннибалов есть жесткие правила и несоблюдающий их индивидуум будет "съеден" в прямом или переносном смысле :russian_ru:
    Если я правильно тебя понял о чем ты ....
  5. Vladimir ® *WehrWolf*
    ko4evnik. - мысли в слух....
    Afrika - На Вашем месте про обострения, я бы воздержался... (просьба - не грубить и не ерничать - раздражает).
    Хомяк - правильно понял + подтекст я думаю ты тоже понял к чему это все !!! :)
  6. Afrika
    Afrika Пользователь
    Веста
    Я грубить не собираюсь и не ёрничать, просто сам подвержен таким обострениям... Подобные мысли не возникают на пустом месте, обычно их провоцируют какие-либо действия или же наоборот бездействия.. В вашем же случае следует искать причину подобных высказываний, или же возможны временные проблески временного осознания реальных процессов, протекающих в обществе...А вот эти самые процессы очень туманят мозг, что даже хочется от подобного цинизма уйти в тайгу...
    Это я к тому, что далее надо искать корни причин и либо принимать их или же......
    Вопрос в том что вам самим надо и что вы можете....
  7. Vladimir ® *WehrWolf*
    Afrika -действия индивидуумов в обществе ... Обидно - да... :) Ладно - забей! Все гуд ! Респект тебе и Уважухо !!! Что не равнодушен к крику души !!!
  8. Хомяк
    Ура! Нас наконец-то услышали!!!
